I have a 1984 mercruiser
model 488
4 cylinder
Alpha 1
present prop # 4214 aluminum
boat is a 21 ft walk around cuddy sea ray
I don't push boat, used for intracoastal fishing , just thinking about
changing hoping too get a little more power.
No trim tabs, infact tabs were never installed when boat was new
I realize trim tabs will help and planning on doing at some point but in mean while considering changing prop.
Presently throttle handle all the way down, at full speed, engine rpm never red lines and cruises around 4000.
engine makes no unusual sounds at full throttle., or sounds of slipping , runs good.
Not sure what prop mfg suggests on this engine
what should I consider too get more speed,? larger or smaller then mfg reccomends
Stainless?
5 blade?
Boat stays on trailer , lower unit and bottom of boat clean like new.
thanks for your help
model 488
4 cylinder
Alpha 1
Stainless?
5 blade?
