SCALDED CAT
- Feb 8, 2013
- 7
I took the carb off a 2002 30hp 4 stroke without taking note of the fuel lines. I know! Now I have a handful of pipes which I am pretty sure do not go to fuel as they were just sitting pointing upwards. However I would like to be sure so if anyone can kindly set me in the right direction I would be grateful.
Still having a bit of bother with carb fuel lines. My carb is a Keihin J95A PE17 BMC if that makes any sense. It has an extra four places for pipes which I am pretty sure are just breathers as there was loose fuel pipes sitting up behind the carb but connected to it. They are on the opposite side to the throttle linkage and high up on each of the triple carbs. All the diagrams show a carb without these extra fuel nipples. Any help most welcome.
