I put a new starter on yesterday. the starter engages the flywheel but will not turn it. the battery is well charged. I drained the lower unit and had no water or metal shavings in the oil. I also took the 4 plugs out , put it in gear and was not able to turn the prop. last time I used it, a week ago, it ran fine. I heard no unusual noises. pulled up to the dock turned the motor off, got my truck trailer and loaded it up. a week later go to the water and heard the starter engage the flywheel but it wouldn't turn it.if anybody has any suggestions, I would be most grateful.
