According to summit racing the bearing fits from 1968-2005.
And it probably dose. Different bearing manufacturers do different things. Some bearings out there will come with groves in the center for oil retention, while others don't. As long as you ordered the correct bearings for the application (std size, .010 under, .020 under, etc), and you confirm proper clearance with a Plasti-gauge, they should work.
