Rustoleum Paint or Spar Urethane...
AussieXLT
Im replacing the old wood in my Cobalt and curious what would be best to seal up the new plywood I have... I have some Oil based paint laying around, but in another thread i saw that you guys recommend Spar urethane...
Which is better?
a1964rn
Re: Rustoleum Paint or Spar Urethane...
If you already have the paint, I'd use that, if you have the color you like.
Woodonglass
What Wood??? Stringers, Transom, Deck ??? Is this a Glass or aluminum boat?
AussieXLT
My mistake... Sundeck/sunpad... and some seat cushions
StevenT
I wood recommend sealing your new wood with some epoxy resin first before painting. The epoxy will soak into dry wood and preserve your wood much longer than paint alone.
jigngrub
I think the clear wood finish of exterior grade spar urethane would look better on your fiberglass boat, probably last longer too.
chrisf695
Ive been told this already in another thread... Spar urethane...
