Re: mercrusier 260
The long block will be basically the same, if the automotive engine is a truck, then the cam should be ok.
You would need to replace all the core plugs to brass to prevent them from corroding.
That cures the block problem. All the accessories, like the fuel pump, carb, ignition system, charging and starting systems all have to be marine for fire and explosion safety reasons.
