Evinrude 3706c will only run if the choke is on.
jkeys0218
Last week i purchased a used 10ft flat bottom boat with no engine. Yesterday I got a 1967 evinrude 3706c for $50. It sorta runs if you leave the choke on but dies as soon as you push it back in. This is the first outboard ive ever had and i know nothing about them so any information would be helpful.
kbait
Re: Evinrude 3706c will only run if the choke is on.
Make sure fuel is flowing to the carb. Remove fuel line at carb and turn the petcock 'on' w/tank vented. Should be a nice stream. If that's ok, sounds like you have a gummed up carb. Remove and clean well, making sure the idle passages and main jet are clear. Here's a great read about your motor: Mastertech Marine -- TUNE UP SMALL EVINRUDE OUTBOARD!
Good luck!
