Hi boating people....i have a early 70's johnson 4hp outboard...it runs great all day trolling but when i run it a higher power maybe half throttle and higher it quits and wont restart until it cools off. It just slowly dies. I have cleaned the carb, put a fuel pump kit in it, installed new points capaciaters plugs and leads, when it dies it still has fuel; the bulb is hard and i checked at the carb. I have also installed a new water pump. There is always water shooting out the water hole but im not sure if its enough. I suspect im having a heat related problem. Has anyone had a similar issue and what was the problem? Also does anyone have any pointers as what to do next?
