First off, I appreciate any help or recommendations you guys can provide. I am a car guy and know just enough about outboards to get one to start.
I have a 1989 Johnson 90 that I picked up for my 17ft Bass Tracker. Guy I bought it from says it runs great, yada, yada, yada. Anyway, at first I did think it ran ok but I took it out on the water and it feels like it has a miss and it is terribly inefficient. Burns gas about as fast as I can put it in it. The boat runs at about 40mph with three adults so I think it is probably making correct power. Compression is 110 on the lower cylinders and 120 on the top. Ignition switch was bad and has been replaced with a new one. After running it for more than a couple minutes, either on the muffs or in the water, it won't shut off with the key. In fact, it runs better with less miss when I turn the key off. It seems to idle down some when I do this. Sometimes I have to pull the fuel line to get it to die and sometimes it does it on its own. I did try grounding, I believe, a black/yellow wire at someone's suggestion and it did nothing. I started looking at power packs and noticed that my motor has older style power heads, 1987 I believe as it has two packs. There is a sticker on the motor bracket and ID marks on the top of the motor that confirm that it is an 89 model. I have seen elsewhere that it is somewhat common to have an 89 motor but 87 heads and power packs. Anyway, one of the packs looks to be spliced in so I checked the part numbers and the spliced one is 582811 and the other is 583110. The second one appears correct through research and the first one is from a 1985 model 90. Will running two different packs cause the issues I am having? I was gonna replace the older pack just to see, but they are a little expensive to just throw at the motor. Once again, thanks for any help.
Forgot to add that the VRO has been removed and it has an "old school" fuel pump on it. I don't remember the model off hand but I do know that it was the correct one for the size of the motor per two different repair shops.
