Re: What Kind of Trim/Tilt Fluid
I have used different suction or pressure techniques. I used to be anal about getting it all out, but have to admit now I just drain the bulk of it and be done with it.
You will need to bleed the system as you know, and add more fluid as you do. Cycle 5 to 6 times, leave in the up position, fill, cycle 5 to 6 times, leave in the up position, fill, etc.... until you can fill no more.
