When i go to pullstart the motor the rope will not move inless i move the shifter about a 1/4 inch to the revers direction! is there a linkage adjustment i can make to fix this? thanks
That is made so that you don't start it in gear. Adjust the nut on the cable so the plastic knob releases the pull cord lock
on the top of the plastic housing.
