Ok, listened to everyone (thanks one and all) and went back to the drawing board. I eliminated any possibility of mixing 24 and 12 volt, and got rid of the relay due to failure issues / concerns and provided for any amp load you care to use. Then, just for those that want it, I put in an optional Buck Boost Converter to run accessories (lights, radio etc.) from the deep cycle batteries regardless of them being in 12 volt or 24 volt mode.
Three Pole Double Throw switch options:
100 Amp current ($35) 100 Amp Disconnect Knife Switch 100A 3 Pole Circuit Breaker Backup Generator 3 | eBay
225 Amp current ($90) 225 Amp Disconnect Knife Switch 225A 3 Pole Circuit Breaker Backup Generator 3M | eBay
400 Amp current ($150) 400 Amp Disconnect Knife Switch 400A 3 Pole Circuit Breaker Backup Generator 3L | eBay
For the OPTIONAL 12 volt accessory convertor ($160) (8 Amps but larger are available) Buck-Boost DC/DC converters 12 volts to 12 volts, 24 volts to 24 volts, 24 volts to 19 volts, 12 volts to 6 volts. DC/DC conversion
I am selecting the UDC-1212-8 modle as it will accept an input voltage as low as 10 volts (discharged deep cells) and as high as 40 volts while maintaining a regulated 12 volts. It does not matter which mode the batteries are in (12 vs. 24) or if the batteries are being charged from the alternator. As I said this is totally optional but would be a real benefit for those that need to run accessories and NOT run down the starting battery.
With the knife switch in the shown position the house batteries are wired for 24 volt output and there is no connection to the Perko switch at all. (The fact is, if desired the Perko switch could be eliminated.)
With the knife switch "thrown" to the other position both house batteries are wired for 12 volt output and made available to the Perko switch and ALL three batteries can be used for starting and will be charged by the alternator.
If the knife switch is in neither position (off) both "house" batteries are shut off and there is no power to the Perko switch or the Trolling motor (accessories will still receive power from ONE battery). If desired a small toggle switch can be added to disconnect the Buck Booster.
Advantages:
Can charge all three batteries from engine alternator.
Can use all three batteries to start the engine.
Complete isolation of the 24 v from the 12 v systems.
Can run 12 volt accesories without draining the starting battery or "tapping" a single house battery causing uneven wear on the house batteries.
Questions, thoughts, suggestions???
Advantages:
