Looking for some advice here. The issue is fuel. The motor runs out of fuel. I have been up and down the fuel tank, fuel lines, carb, replaced the fuel pump diaphram, primer bulb and hose.
filters are clean. I have put alot of time and effort into finding the source of this problem. At the very least, I am fed up! But, being stubborn I'm determined to fix it. I have come to the conclusion that the issue lies somewhere in the fuel pump system. I checked for vac leaks and check for any plugged openings and replaced the hoses. Found nothing. Whats my next step? I am thinking I may have to check the reed valves. That should be an adventure. Dont really want to go there, but i will. So if you can think of anything please let me know. thanks, JBK
