Greetings,
This is probably a dumb question but I need to ask it anyway.
I know when working out the AWG size of battery cables, the length of the proposed circuit is a critical part of the calculation. But how is this applied in a dual system where you have a cranking battery, a house battery, and a three way battery switch.
The cranking battery's circuit runs via (+) red from the battery to the switch (1) then via (com or both) to the starter motor, and returns to the cranking battery via (-) black. The deep cycle house battery will be connected via switch (2) but won't be used for cranking the engine.
So let's suppose there and back in the cranking circuit is a run of 10 feet. Is it necessary then to also included the house battery circuit into the equation? , because the run then would be more like twenty feet.
Thanks,
bluey.
Thanks,
bluey.
