merckoutboard
- Jan 9, 2013
- 7
I recently got a 1988 Bayliner handed down to me from a relative. The deck is rotted out up through the middle from the stern to the bow. The boxes for the seats in the aft are also rotted out. Where the deck starts to curve up towards the sides and the seat boxes in the middle of the boat do not appear rotted. I know I need to replace the deck but do I need to replace all of it or can I cut out where the rot is and tie into what is good? My other question is if I use marine grade plywood to replace the floor is it necessary to fiberglass overtop or can I seal it with a resin or polyurethane? I am going to carpet over top once I replace the deck. With the use of marine grade plywood is there a way to avoid fiberglassing?
