Re: New 20 HP mercury owner
There should be a tab with a good size hole in it on the transom tilt tube or near there that can have a chain, or cable run through the brace in the boat. to stiffen the transom that you can at a saftey chain and lock it to the motor. This along with the bar lock cover Windy talked about will help stop ones with light fingers, and will also keep the motor from going to the bottom of the lake if you happen to hit someting and the motor comes off the boat. Doing the chain deal is known as a saftey chain and could save one a bundle of $$$ in the long run. And yes I have seen it happen more than once. JMO
Oldman570
