90 Hp Johnson tilt/trim trouble
KAI KATCHA
Ok, tilt was working fine yesterday but today only getting clicking sounds from relays and sometimes clicking at pump motor?. Have checked relay volts and both have 12v through them , motor was a little nosier then usual when lifted after cleaning?. Model number AJ90TLCDC think its a 1987 can anyone help ? .:eek::facepalm:
Will Bark
Re: 90 Hp Johnson tilt/trim trouble
Try lightly tapping the motor with butt of screwdriver and see what happens; may be a brush sticking. Good luck
KAI KATCHA
Thanks tried that straight away with little improvement if i flick tilt switch enough can get tilt motor to run , very slow and not sounding good at all, loud groan and shuddering with no tilt up
boobie
Take some jumper wires and go directly to the tilt mtr itself and try it. If it still groans, it would sound like a bad t/t mtr. If it works okay, look for bad connections in the system.
deebury
Is it possible there's an airlock in the system ? May require bleeding or top up of oil ? Sounds like the ram might be cavitating (sucking air)
Just a thought ?
KAI KATCHA
thanks for everyones ideas / help tried all that was suggested, removed the trim/tilt complete set up from outboard (without removing motor from transom ) very simple :joyous: . pulled trim motor cover off and heap of oil,and broken magnet. Would explain the noise got new motor on the way with new seals .
