Good morning.
I'm still looking for a 24-26' Express Cruiser as some of you might be aware. Fun & time consuming process. Learn quite a bit about boating in general, but still no where enough to arm myself yet.
1) So can you please help me with any rule of thumb on the power (HP rating?) of the engine I should be looking for?
- What's a min engine size for a 24' (~5000 +- a couple hundred lbs)
- Average size?
- "Powerful"/plus size?
I saw some of the replacement engines on older boats (96-2001) have 5.7 Volvo Penta 320Hp. Some the of original is only ~260HP. But can't relate them yet.
2) If average maintained, how long the engine should last before a rebuild/major is required? How much is a ball park guestimate for this?
3) If it has a closed cooling system, does that mean salt water proof? I plan to take it out the Bay (CA) once in a while. With good clean up, will it still keeps my boat as clean as a fresh water only boat?
4) anything other general important points I should know at this time (pre-purchase)?
Thank you.
Nhi
- Average size?
Thank you.
Nhi
