halmc
- Feb 27, 2008
- 231
"Stumble" is probably the wrong word. My pontoon boat 25hp four stroke egine occasionally dips rpm for half a second or so, and does so at intervals anywhere between six or seven minutes, on the long end, and 45 seconds or so on the low end. I'll be cruising at 2500 rpm or so, and the engine will drop to 2100 rpm for maybe a half second, then return to 2500. Otherwise, it runs perfectly.
Here's the weird part: If I remove the engine cover, it might dip once in a half hour. That's not speculation. On a three hour journey yesterday, I made all sorts of changes I could think of -- including idle mixture -- but the major variable was whether the engine cover was on or off, and I repeated that operation enough to firmly believe that my observation that the cover removal affected the engine is accurate.
I have carfully inspected to determine whether the engine cover was somehow mashing a fuel line -- it isn't, or restricting air flow to the carb -- it isn't.
In another thread ("my bowl runneth over") I described a far worse problem, with the carb flooding and causing real serious engine stumble. A carb rebuild kit fixed abo0ut 98% of that issue. What I'm left with is this intensely annoying rpm dip, that seems to sense when I'm nearing a leeward shore, or docking the boat.
The rpm dip occurs over the entire rpm range.
Things I have not yet checked:
integrity of the o-rings in the intake path. But it idles too well for a vacuum leak.
Possible accumulation of water in the fuel. (tho' I have drained the bowl more than once with no discernable effect.
Spark plug condition
Fuel pump output. But it runs WFO for thirty minutes w/o a stumble with the cover off.
The rpm dip is not an ignition miss, which would be somewhat more pronounced. This dip is as if I had throttled back momentarily -- for less than a second -- then returned to cruise.
While the boat goes everywhere I want it to, and docking is not overly affected, if it were an airplane, I would not fly it until it was fixed.
The engine cover thingy really has me stumped. It coudl affect the temperature of the things like the coil, but hard to believe it would be that sensitive/marginal.
Comments? Suggestions? Remedies?
25hp-four-stroke-model-1f25412dd-serial-1b169120
