Re: In winter, outboard prop in or out of water
Motor down to protect from freezing. Not much marine growth. and in most places the air gets a lot colder a lot quicker than the water.
Mine's at the house inthe water so I lower it when it calls for sub-freezing weather, but I don't worry about messing it if it's high 20's. Water temp is seldom less than 38. But even though I haev been doing this for the 4 years I have had this boat, a friends across the cove with the same motor has NEVER lowered his motor and he's been there about 6 years longer than me. So while it's not likley ot be a problem if you don't, why not be safe.
But you'v efound the beauty of the OB--low low maintenance and no need to put it out of commission for the winter; no hassle to start up early in the spring; no risk if you don't winterize.
Remember a boat on a trailer with the motor up will accumulate rain water in it which can freeze.
