  #1
Old September 4th, 2004, 06:38 AM
Rigby Rigby is offline
Default building Aluminium pontoon
G'dayRigby's missus here looking for some assistance. He has been trying to find out some information, plans, anything in relation to building a fairly large size pontoon style platform suitable for us to build a houseboat onto. We have three daughters that are growing up fast therefore comfort and space is rather an important factor. After alot of research and deliberation we think that a pontoon type would serve us well, we sort of want to be able to escape the rat race when not working in super comfort on the water. Rigs loves to build things and is great working with all kinds of metals we live on property so size and space to build this is not a problem. Also have access to moorings so size for trailering is not a factor. Would love to hear from someone that may have done this themselves or knows of somewhere we can obtain plans or advice. Thanks heaps Janette.
  #2
Old September 4th, 2004, 01:49 PM
Winger Ed. Winger Ed. is offline
Default Re: building Aluminium pontoon
Do a internet search for 'boat plans'. There are several sights with free plans you can download and scale up, or on others they sell plan sheets that are sort of like blueprints for a nominal fee.Another option is find an older one and restore it. Often you can find boats with broken engines or need a refit that are almost free if you haul them off. That might be a good source to get the pontoons themselves if not a whole boat.Ed,
  #3
Old September 4th, 2004, 03:20 PM
tmcalavy tmcalavy is offline
I did a web search for homemade houseboat or home built houseboat and came up with a site where a couple were building just what you describe, entirely wooden I think. Can't remember the site URL, but I bet its still there...could have been DIY houseboat. Give it a try.
  #4
Old September 7th, 2004, 01:45 AM
Winger Ed and tim Mc, G'day, thanks heaps for replying. Had a bit of a surf on the net last night re pontoon houseboats and found some good info. We realised that all our original searching for boat plans had been mainly on v-hull design. My boat design search begins again, which is what I love to do when I find the time, natural female instinct I guess (always looking for something). Ha Ha.Thanks again guys for your time and great info. Janette (The Missus) P.S. Winger Ed - Hydro looks great.
  #5
Old September 7th, 2004, 03:10 AM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
Janet, I'm in the middle of doing the exact same homework. My wife and I are looking at buying a 40ft houseboat that needs new pontoons and motor (just like 'Ed' described).40ft marine grade alloy pontoons are not cheap but they will last much longer than sheet metal, you need to do accurate sums to determine if alloy is cost effective. In my case, about $25,000 for the pontoons, including a solid alloy full length bumper. At this stage I think I will get them custom made so that I can incorporate water tanks, septic tank and fuel tank. The most up to date pontoon design is a square box profile that tapers slightly in the last few inches, the bottom is flat. The front section of the pontoon is racked to help cut through the water.I've looked a hundred of houseboats in the past few months and have come to realise that they are deceptively simple to build. Think of your pontoons as bearers, add joists every 900mm (depending on the size of the material), add noggings between the joists to support the floor, add a marine ply floor (or plate alloy floor) and build a house on top. The house framework can be light gauge box steel or kiln dried treated pine. The rear section of the joists are beefed up to accomodate one or two motors. Its much easier to build the rear section to suit outboards as opposed to I/O.Aldo
__________________
Watch this space......................
  #6
Old September 7th, 2004, 05:20 AM
petrolhead petrolhead is offline
You don't mention an actual length, but have you checked out the Glen-L website? They have houseboats from 16' to 45', mostly plywood hulls but the biggie can be plywood, welded steel, or GRP. With something as simple as a pontoon hull the plywood ones should lend themselves to steel or aluminium construction too, all you need is the shape which is a basic box with a point at one end!
  #7
Old September 7th, 2004, 11:37 PM
Aldo, Janette here thanks heaps for your message. Great info. Hubby is in the shed at the moment tinkering with an outboard that he is rebuilding. I will get him to read your message when he comes in for dinner. It's great to see that you are thinking along the same lines as us. We have definately decided that aluminium has to be the go, understand that it will cost us a bit more but think it is well worth it. We are looking for something around the same size as yourself and originally were looking at the Roberts Atlantic 40 in alloy as a build but after many many hours of research and discussion feel that a houseboat is a better option as our three girls are 8,9 and 10. Maybe look at v-hulls further down the track. I will have a look for some restoration housey's as well which I think is a pretty good idea. Thanks again heaps for your info, Rigs will probably reply a bit later on for maybe some more info. By the way good to hear from a Melbournian, I am born and bred in Ballarat and miss the people down there majorly. Very different here in Sydney and not getting much better by the day. Hense our future plans.Kind regards Janette.
  #8
Old September 8th, 2004, 08:18 AM
18rabbit 18rabbit is offline
“G” day at you, too. Just a thought … here in the San Francisco Bay it is not uncommon to see barges that have been made into homes and/or offices. They are really nice. I play in a boatyard that purchased a couple surplus military barges ($12k ea) and made them into machine and wood shops. They are big, heavy steel boxes that are 30ft wide, 60ft long, 15ft high. Cut in a sun roof, has doors on two sides, a deck on one side. You can cut in windows, grow your garden on top…Before you commit to spending $$$ on this venture start with a feasibility study. Can you find a place to moor your new home? This is the single biggest problem in the SF area. No where to park your floating paradise. We had an opportunity to purchase one of this barges ready to go ($40k) but we are unable to find a place to put her.Search the web for barges. Lots of brokers selling barges in England, US, Europe. I would image in your area, too.
  #9
Old September 8th, 2004, 04:01 PM
Dunaruna's Avatar
Janette, 18rabbit makes a good point, where are you going to use the boat? Couple of things to concider, a 40ft pontoon houseboat (as opposed to a 20ft wide monohull) won't handle coastal conditions, they are just not designed for heavy swells and the occasional storm but they would be great for the Hawksbury river system or Myall lakes.The life span of aluminium is greatly reduced in salt water unless you spend "Greg Norman' type money. Aluminium pontoons are very popular on the Murray system, try searching boat builders around Mildura/Echuca/Albury etc.40ft is not easily or cheaply transported. Where it is slipped is usually where it stays, a single story 40ft x 15ft generally weighs in at around 10 to 12 ton (a rough guide, way to many variations).In my case I am looking at Lake Eildon, perfect for alloy pontoons although I haven't seen any on the lake, don't know why. Cost maybe - dunno.My wife and I recently toured the Whitsundays' for 2 weeks in a 39ft alloy cat (rental). What a boat! About $450,000 to buy, I'm only $420,000 short but this cat needed to be slipped, cleaned and painted every six months at a cost of $6000, not exactly within the price range of the average punter.Aldo
__________________
  #10
Old September 22nd, 2004, 11:00 PM
Dunaruna's Avatar
Janette, any progress with the pontoons?Aldo
__________________
  #11
Old September 27th, 2004, 05:55 AM
RedNecker RedNecker is offline
Try http://www.custompontoonboatkitsetc.com/_wsn/page7.html Email or phone. Ask for Jeff. Describe what you want. He also will do some of the work if you want that.I purchased a set of pontoons & crossmembers from him. I am building a pontoon boat.Here are some pictures of my progress. http://groups.msn.com/PontoonBoating/rednecker.msnw It is a lot of work, But I enjoy that.red
  #12
Old October 14th, 2004, 08:24 PM
Dunaruna's Avatar
__________________
  #13
Old November 10th, 2004, 08:26 PM
Dunaruna's Avatar
__________________
  #14
Old November 11th, 2004, 05:44 PM
steve n carol steve n carol is offline
rednecker, well done, I enjoyed the pics too!...sl
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Building Pontoon Floor.... bherron Boat Restoration and Building 12 January 30th, 2007 05:14 PM
building a hardtop for a pontoon flashback Boat Restoration and Building 7 October 9th, 2006 09:31 PM
Building small pontoon boat bayman Boat Restoration and Building 25 July 5th, 2005 02:57 PM
Filling Aluminium tengals123 Boat Restoration and Building 2 March 21st, 2005 02:07 AM
Foaming an older Aluminium 4.2m runabout a bad Idea ? Corrodes Aluminium ? Got a Boat Boat Restoration and Building 1 March 2nd, 2004 07:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
