tilt not working on 1998 yamaha 150
cboudet
I have a 1998 yamaha 150 outboard that leaks fluid from trim/tilt unit.
Recently the trim is the only thing that works.
the tilt makes noise but does not lift the engine.
I would appreciate any suggestions or pointers on how to fix it.
Thanks
RRitt
Re: tilt not working on 1998 yamaha 150
where is the leak? does trim eventually bleed off?
99yam40
If fluid gets too low it can not lift the motor.
Fill T&T back up and have leak fixed
