Re: Quick Easy Simple Question
Thanks everyone, already went to premix so that wont be a problem. Powerheads look identical and the base gaskets are the same for both models, with the excpetion of some newer electronics on the 40, everything looks like it will be direct retrofit. Thanks for all thelp. if anyone has something different please share it but I believe im going to swap these powerheads. The 40 has a damaged piston due to a major overheat and I can get this running 45 for like $300.
