  #1
Old September 1st, 2004, 06:22 AM
bbalcer bbalcer is offline
Default repair kicker motor mount holes in aluminum
I'm not sure this has been covered, I couldn't find it with a search. I wanted to put a kicker motor mount on the back of my 18' Smoker. The previous owner had a mount (i'm guessing by the 4 bolts sticking out of the transom) but has removed the business end and left the bolts. I doubt I'll find the matching mount and before I put a new one on I'd like to fix the holes that are there now. I'd like to fill em, smooth em, paint em, and forget em. What are options? I have a welder capable of welding aluminum as well as an oxy-acetelyne torch to melt aluminum rods. Thanks in advance for any ideas.BB
  #2
Old September 1st, 2004, 11:06 AM
dajohnson53 dajohnson53 is offline
Default Re: repair kicker motor mount holes in aluminum
Three options come to my mind:Are you sure the old holes won't fit a new bracket? A lot of these things have standard bolt pattern. I'd check that out first - unless you want to change the position of the bracket or do away with it.A good welder should be able to plug the holes and if needed, grind them and buff them to nearly invisible - invisible if painted. If the new bracket is going to cover the old holes, I'd not spend a lot of time, money or effort making it look pretty.You could weld or otherwise attach a nicely shaped and fitted aluminum plate over all 4 old holes (on inside, outside or both) and then attach the new bracket through the plate(s). It could even "look" OEM if done well, and might actually be functional in the sense of strengthening the bolt attachments (like a big washer, ya know?)Just brainstorming here, based on stuff I've done or had done in the past.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
kicker motor mount on i/o millerpdt Freshwater Fishing 4 March 17th, 2008 12:02 AM
Filling inside of Motor Mount Holes on Transom deerhound Boat Restoration and Building 4 November 5th, 2005 12:38 AM
getting rid of old holes from original motor mount holes The Wright Stuff Boat Restoration and Building 6 April 20th, 2005 05:22 AM
motor mount for 7.5 honda kicker flashback Boat Topics and Questions (not engine topics) 0 March 13th, 2003 06:19 AM
How do you determine what holes you mount the motor own striper-chaser Mercury & Mariner Outboards 5 July 18th, 2002 02:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
