Re: 150 hp evinrude outboard electric tilt
The trim system on your engine was used for years and years, with only a change in the system electrics. Generally, it's a pretty bullet-proof system. The reservoir sits opposite the motor on this unit. Midway down the side of the reservoir is a screw. Once the screw is removed, the hydraulic fluid should be full to the lower lip of the hole. Once filled, repl the plug and activate the trim up/down a few cycles. This will cause the unit to self-bleed internally. Remove the plug and recheck the fluid level. If the fluid is still low, you may well have to add to it numerous times, then re-bleed it. If you would like to see the factory exploded parts diagram, this website may be helpful: epc.brp.com
