Blake0912
- Oct 31, 2010
- 310
Hi guys ive posted about this motor (1975 9.8hp 110) before and since then I have fixed my hard start issue (starts on 2-3 pull when cold) , have a new lower unit with good seals , and a new kill swith.
The motor will idle perferct forever I had it running for about 20mins in a barrel , but when I put it in gear and gave it some gas it stalled out, What could be causing this? the carb and fuel pump was rebuilt, and the float and needle valve are in great shape.
Also when I rev the motor up it makes like a scratching/pop noise is this normal? Ill post a video of it running and you can hear what im talking about when I give it some gas.
One more thing , should I have to re-prime the bulb everytime I go to restart it? Ive never had to do this with any other outboard. But after the motor has been running and you shut it down you have to re prime the bulb to get it start again , is this normal for these motor?
Sorry for the bad quality i took it on my phone
Thank You
(Click On Picture to Play Video)
Thank You
