Had previously posted thread 1995 6 cyl. 90 hp. Mercury outboard not started for years Found out Maxz695 and i were in the same city. He had replied to several of my posts about troubleshooting, tests,common problems, etc. Swapped phone #s, he came over to the boat about 1:15 and started tracing & testing. After a short time he had fire to plugs, hooked up gas & muffs, got puffs of smoke & it wanted to go but little gas thru carbs.Have to get kits with floats, clean and rebuild 3 carbs. He was done and gone before 2:30! No spark problem was traced to faulty ignition switch and or man overboard switch with worn key.Both to be replaced. THANKS for your time and trouble, you really know what you're doing !
