As I mentioned in a previous thread I'm looking at a used boat and decided to thoroughly check it out prior to the survey to make sure I didn't miss anything simple.
Boat is a 06 stingray bowrider and after spending about 2 hours on it alone and checking every inch in and out, here's what I found. I have about 200+ photos, if anyone wants to see a particular view.
Walked every inch of the deck and even floor lockers, head, 'motor room', storage areas and swim platform. No soft spots, or any cracks. All electronics work (radio, speakers, bilge pumps, depth finder, trim tabs/indicator, drive trim, instruments, cabin lights, nav lights, pressure pump, bilge pump, etc). 193 hours on the motor. The things I found wrong a few.
Missing carpets, Needs bottom paint, needs new anodes, dime size piece of skeg missing (expected items)
Small oil spill in motor area, mildew from wet items being thrown into closed lockers, foggy instruments, led out on the water pressure switch.
Pictures of the 'offending items' are as follows. I'd like your advice on how big of a deal you think these are.
The below appeared to be new oil and I couldn't find the source on any of the hoses by feeling around anything I could reach. I put my foot in it when standing and felt the oil with my fingers and it felt like new oil, so I'm assuming it's a spill when filling the but wanted the forum's advice.
Also, looking at the fiberglass above the tube on the floor, the fiberglass bulkhead that's parallel to the transom gets darker as you go lower, but felt solid when tapped. Same sound above and below. What might account for the color change. Just dirt/grime?
More motor photos here--> https://picasaweb.google.com/shots2006/Motor?authkey=Gv1sRgCP3hjYiSv4CNgwE#
Below is an example of the mildew/mold.. This example was from under a cup holder.. The loose tube is from the cupholder and was reattached.
Here's the switch light/led (green light for water pressure/pump top right) that appears to be out. Are these easy to replace?
The foggy instruments. The storage in front of the helm had wet lifejackets, which I suspect caused the moisture. Does this just need a good drying out or is this a bad sign?
Example of the mildew. Several closed compartments had wet life jackets, fenders and ropes that I suspect caused this. What do you think, minor or major issue?
What do you guys think? Are these minor issues and should I continue with the professional survery or are any of these deal breakers that suggest I shouldn't waste my time money and look for the next boat?
I'm new to boating and I'm assuming these are common and minor items but wanted a second opinion.
Some photos of the boat in the next post...
