I was unable to search for this issue (but "95" is a tough thing to search - when you want a carb number). I have a 2004 Mercury 40 Jet. I purchased my service manual in 2010. Decided to rebuild the carbs this winter. I was looking through the manual in preparation and the specs (jet and idle screw preset) are not listed for my carb model (95-1, 95-2, and 95-3). The service manual caps out with the 1998 model year! I called mercury manuals from my purchase receipt and after speaking with the technical specialist, my manual is the only one produced for my 2004 motor (even though it was published in 2002). The technician said my carbs should be compatible with the 58 number carbs. I asked if the jets and screw adjustments are the same and he said, "yes." Can anyone confirm this? The jet should be 0.060 in and the initial preset screw 1-1/8 turns for a 58 model carb. Is this correct for a 95 model carb? Any help would be greatly appreciated.
Thanks!
Thanks!
