Carpfisher
- Nov 25, 2012
- 43
So I put a new carb from Marine Engines .com on the 92 70HP that I have. You may remember my last, dead hole at idle post. Well, the new carb seemed to do it. I put in the water, put in gear, no stall. Yay !! motored out of the harbor at idle and just above idle. Something that it would not do before. Went to get on it leaving the harbor and blah...falls on it's face and died. Immediate restart, no problem. This happened about 10 times as I milked it back to the dock. (cuz' I kept trying). All of a sudden vrooom. There she goes on the top end. It was like something was clogged and opened up. Ended up going out for about 3 hours, staying right around the harbor. I have a 4 stroke, 6HP, kicker, oars and all safety equip., and vessel assist. So I wasn't to worried about getting stuck, mainly I wanted to run some good gas thru her. She ran great and smooth, top and bottom end. Shut off a couple times, again 0 problems as far as power/stalling goes.
End of story--noooooo.
So next day, put in water... crap she's taking on water....got a leak that I need to find. Did notice excess water in hull but thought it was from the water splashing over the transom when I was going fast and the prop wash was hitting the improperly placed bait tank pickup and splashing over-NOT...in the mean time, gave it the more throttle test and blah, fell on it's face and died... didn't have time to try 10 times and see if it clears out again, was worried about the leak.
Any off the cuff ideas, I heard fuel bulb- will test and replace today, other known problem-not getting 12v to the enrichment solenoid, need to turn it manually to start and I see it leaking fuel. Only when manually turned. Doesn't leak when running. Will address but wondering what is was the cause of the dying when throttling up. Like I said, one it got going, it went- no problems. Tank is vented properly.
Thanks for any help and guidance-Carpfisher
