Re: Trailer overloaded?
You cannot flip a cambered axle, which this apparently is, unless you also remove the spring perches and have them welded on 180 degrees around the tube. That is a hydraulic line hanging down which was broken off as the axle pounded against the frame. Keep in mind that every bump this trailer hits, the frame and its load rises creating a gap between the axle and frame. As the load comes down the frame contacts the axle again. This is happening a gazillion times in a 30 mile trip and will ultimately lead to failure of something. The frame looks to have about half the lower part of the beam pounded though which is weakening the frame at that point. I would also have a close look at the axle in that same area. Since this was a modification, it may be the rear spring perch was moved to flatten the springs a bit. Only problem is it was moved too much. If there are extra open holes back there then the mount has been moved. If not, then the axle was moved from beneath to above the spring as everyone suggests. As it is, it is definitely not a road worthy trailer. If the GVWR is over 3000 - 3500# (depending on the state) you are in violation of not having functional trailer brakes. Since the system has been open to the air for an extended period, you need a complete system replacement. As a miniumum you would need a new master cylinder and probably the shock absorber as well, reverse solenoid if it has one, new lines, new brake hoses, and rebuilt wheel cylinders and probably shoes. Since that's about 85% of the entire system, go for complete replacement and be assured the system works when you are done.
