hey all,
A couple of months ago I purchased a 1970 25hp Evinrude 20052e for $150. The guy said the carb and fuel pump were replaced in August, but I have my doubts. Since purchasing it I have rebuilt the carbs, replaced points and condensers.
This week I put it in my barrel to see how it would run with the new improvements. It started right up and only ran for 30 seconds and then was unable to start back up. After waiting a day I lifted the gas tank up a foot above the motor and tried again, a couple of pulls and the motor started right up with choke on. Over about 30 seconds I eased the choke off and let it run for another 30 seconds, then it died. I pulled out the plugs to do a spark test and seem to have good spark on both cylinders. However the top cylinder plug looks like:
And the bottom:
I am running with new fuel and thought it might be the fuel pump. My plan for the future is to move my gas tank to the front of my 14' boat, so I was planning on rebuilding the fuel pump anyways. However, now that I pulled the plugs out and saw that one was fowled and the other fine I am not sure what to think.
After putting the motor up on my stand I went to drain the lower end oil and only water came out. The hole in front of fill plug was draining black fluid.. any suggestions there?
And the bottom:
