kelmer1988
- Jan 20, 2013
- 4
Hey guys,
Im hopeful this issue can be resolved with some simple fixes. So here we go:
I have been running my 15hp Evinrude 1983 motor for 3 years strong. I have taken the lower housing off and examined the water pump every 3-5 months to makes sure the impeller and everything still looked good in working condition.
Everything looks good, but my recent outing on my lake an issue arised.
I was going on plane when i decided to stop really fast to slow down. I guess you can call this braking on the water haha.
Anyways, after i did that, My water stream stopped peeing....
So went home took the water pump off, examined it, everything looked good.
Also:
I stuck a hose w/ a rubber tube, connected it to the copper pipe, and shot water up the copper pipe in the motor (while it was shut off of course), and water came out the pisser just fine.. so no blockage.
(long story short)
I put the water pump back on, screwed the lower housing back on, turn motor on (pull start) one pull turns on, and the water stream is weak... then it STOPS, so I I gave it more gas, put into forward gear, and the water started peeing again but still weak, then I Put motor back to neutral/idle, and the water stopped coming out of the pissor.... WEIRD?
TODAY, present time, I replaced the whole water pump. New impeller and all. I scraped all corrosion off, and made sure there werent any clogs in the copper tube again w/ the hose.. So good to go..
Connected the water pump, Turned engine on, with two pulls and ignites and SAME ISSUE... weak stream.. then stops...
Well here we go, theres my issue.
my thoughts.. thermostat? I put one in there three years ago... maybe thats preventing the water now?
anyways any other thoughts would be amazing!
Thankyou for taking the time to help,
~Andy
Also:
(long story short)
~Andy
