Re: Zincs on DP-E outdrive question.
Thanks, Don, I have two on order.
One quick question: The transom shield ground wire runs from the water inlet bolt to the top right transom shield bolt and the tiller bolt (the bolt that holds down the trim sensor), is that correct? Sorry, took it off and forgot where it hooks up.
