Re: How to detirmine throttle cable for a 78' Glastron HP154 Bass Boat?
BK:
here, the info you seek can be found. Of those,
this is one makes sense. Make sure you keep the cable keepers off both ends of the throttle cable, they may be hard to find...
Make sure to measure the maximum length at steering wheel lock. If it's a typical starboard helm, w/ gunwale mounted controls, that means the wheel is turned fully left, making the throttle cable longer whether the cable enters the cowling on the left, right or front of the motor.
