motor was running now nothing
bd07
Have a 70s model johnson 40 hp. water was not comeing out the pee hole and carb was flooding out but the motor would run. got the carb squared a way to the best of my knowledge and replaced the impeller for the water pump. now motors not running at all tweaked the carb couple times and still nothing. Any advice
Lone Duck
Master Chief Petty Officer
Re: motor was running now nothing
Do all
Do ALL your checks starting with spark and compression and carry on to fuel system till you find problem. Squared a way carb?? What exactly did you do? Sounds like you need to do all system maintenance .
kbait
Agree w/checking for proper compression and proper spark^, if that's looking good, spray a bit of premix into the carb throat and see if it'll run briefly.. If it does, you have a fuel delivery issue.
Good luck!
Bob_VT
Welcome to iboats.
A 1970's motor? I would get a manual, a wheel puller and also check the electronics under the flywheel. You would be amazed on how nice things work when you sand off a bit of corrosion.
I would probably do the entire system...... plugs, points, carbs......just based on the age.
