  #1
Old August 22nd, 2004, 06:09 AM
alderman alderman is offline
Default Starcraft Aluminum Paint and seats
I have found a old starcraft aluminum deep V 14' fishing boat. The hull is sound but the inside and outside needs some paint. Any ideas on what type of paint and how best applied, also what prep. work needs to be done. The seats are wood, the front two look to have been replaced, maybe with redwood. What is the best type wood to use? Anyone tried the man made products yet? Will the same type wood also work for the transom?Thanks in advance
  #2
Old August 22nd, 2004, 09:08 AM
mellowyellow mellowyellow is offline
Default Re: Starcraft Aluminum Paint and seats
as for paint, any lose/flaking paint needs to beremoved. any bare spots need a zinc-chromate primer.many top-coat choices avail. once it's sealed.be careful, some marine paints contain copperand it will react with the aluminum.a good all around product I like is called "gluvit".even helps seal leaks.good luck,M.Y.
  #3
Old August 22nd, 2004, 10:20 AM
imported_John_S imported_John_S is offline
I have a 60's 14' Starcraft, but its a modified V, wouldn't say it is a deepV. It is a light green color. The original seats did have a redish color to them, but I don't believe it is redwood. My front and rear seats are still original, but have been primed and painted with oil based white enamel, a number of years ago. Same wood is found on each side of the steering console, and in the bow. The middle driver seat, which is part of a hatch, had split many years ago, and was changed to plywood. The transom wood, I believe is plywood, but havent had an issue where I needed to remove the aluminum around it, to know for sure. Boat has held up well over the many years. Never had any rivet leaks. The original flooring has finally bitten the dust, and will be a winter project for me. Will convert the old steel cable steering to Teleflex, as well.
  #4
Old August 22nd, 2004, 11:55 AM
Thanks for the tips guys, this boat is just a open fishing boat with three wood seats, I think this boat is from the 60's also. Just finished filling with water got one stinking rivet that drips. O well guess I bought a junker. Thanks again
  #5
Old August 22nd, 2004, 12:09 PM
DJ DJ is offline
One leaking rivet does not make a junker.Here is the aluminum painting process.1. Sand entire boat with 120 grit wet sandpaper.2. Wash entire boat with 50/50 solution of vinegar and water.3. Apply one coat (thin) of zinc chromate paint.4. Wet sand with 120 (very lightly).5. Apply one coat "Metalprep" primer. 6. Wet sand with 120 grit.7. Apply finish coat of one part epoxy paint. I used Interlux "Brightside" one part epoxy-white.8. Wet sand with 220 grit wet sand paper.9. Apply final coat of "Brightside" one part epoxy paint.Hints: 1. Use only the thinners approved by the paint manufacturer.2. Use very high quality brushes.3. You will need one quart zinc chromate, one quart metalprep, two quarts final coat-Brightside.I brushed mine. The Interlux paint flows out beautifully. You have to get very close to tell it's brushed.All of the paints and thinners mentioned above are available at: www.westmarine.comYou could also use the products available from Pettit Paints. I used Interlux this time, because it was on sale.
  #6
Old August 22nd, 2004, 02:09 PM
DJ: I was only kidding about the leaky rivet, thanks for the vary detailed painting process. It is just what I was looking for. This site allways comes up with the best information. Thanks Again.Anyone have any suggestions for interior paint?
  #7
Old August 22nd, 2004, 09:15 PM
DJ DJ is offline
Alderman,I know you were. Use the same process on the interior. You may want to use a flat color on the inside-your choice. The key is the prep. (zinc chromate)With that leaking rivet, just make sure it's tight and apply a product called Gluv It on it and any others you suspect.Gluv It-available here:www.westmarine.comLet us know how it goes.
  #8
Old August 23rd, 2004, 03:06 AM
Thanks again DJ, just found this old hulk a couple of weeks ago in a outside storage lot where it had been stored for three years. Got the 1963 seaking running, trailer is again now road worthy. I want to at least get her in the water once this year, then get all the rust off the trailer and repaint the boat and trailer. Should keep me out of trouble most of the winter. Thanks again for all the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starcraft Boat seats WanabeBoater Starcraft Boats 8 July 26th, 2009 10:29 AM
Removing seats in Aluminum 14' Starcraft dave524 Boat Topics and Questions (not engine topics) 5 February 25th, 2007 08:39 PM
Overcoating original paint - Aluminum 1973 Starcraft djfam Boat Restoration and Building 3 March 22nd, 2006 04:58 PM
Starcraft Aluminum Boat Paint....what was it? neebishis05 Boat Restoration and Building 0 November 7th, 2005 02:45 PM
Aluminum bench seats FLATHEAD Boat Restoration and Building 1 April 24th, 2004 08:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
