Re: Tilt Motor Identification
the motor and pump are NLA. It is a 3w prestolite. replacement motors are cheap and adequate. replacement valve bodies of same quality are non-existent. you can get a chinese for around $100 but it is very crummy quality made from cheap soft metal and low grade seals. the manual release was only used aon a few chrysler, evinrude, and johnson engines. be careful not to damage the screwdriver fitting on manual release and have it rebuilt when system starts drifting down.
