I have rebuilt a 1984 Johnson 70, but now I cannot seem to get the thing to fire. I have tested the spark, easily jumps 7/16 open air gap with new spark plug wires. Compression is 140 psi on all cylinders so that is good. Which leads me to believe a fuel problem. I have tried spraying premix into the cylinders with the spark plugs out then turning the motor over after putting the plugs back in and nothing happens. Tried to spray premix into the carbs while starting and nothing happens. I took the fuel pump off and rebuilt it and it appears to be working fine. When I squeeze the bulb it gets hard and the carb bowls sound like they fill up with fuel. I am not sure what else the problem is, too much air getting into the system through leaky hoses (only one of the hoses from the fuel pump had a clamp on it), sticking floats in the carbs (I rebuilt them while working on the motor and put in new jets), a sheered flywheel key, or a blown primer solenoid? Any help would be appreciated. Thanks.
Plugs look dry when I take them out.
