I have recently acquired a pull start, 1974 25-HP Evinrude in excellent condition (low hours). I have replaced the kill switch, both ignition coils, coil under the flywheel, points, condensers, spark plugs, and set all to specifications. I am using a new fuel tank, hoses, bulb, and connection fittings. I have soaked, cleaned and rebuilt the carb. (using a carb kit).
When rebuilding the carb. I had trouble trying to insert the plastic slow speed needle valve bearing, so I called the guy at the marine store where I bought the carb kit and he said, "the part was more trouble than it was worth", so I did not install one. I have the motor in a 60 gallon water barrel, which causes the motor to hang about 15 degrees forward from straight up and down (it's like when running in shallow water position).
I started by replacing the 2 ignition coils first, (one was cracked and no spark) it didn't help. Then I replaced the coil under the flywheel, points (set @ .020), and the condensers. At this point in the process it would start, but only with starter fluid, (I know this is bad and why). Once started in would run OK, just a little rough at idle, (I think adjustments will cure that). Even after letting it warm up for a minute, once I shut it down it would not start again, except with starter fluid. It seemed to have fuel running out of the throat of the carb, like it was flooding. Then I got a carb kit, disassembled the carb, soaked, cleaned and rebuilt it. It still doesn't start correctly. Someone I know suggested, (I don't really trust their competence in this situation) it might be a synchronization, or timing issue.
I am not an OB mechanic (duh...) or I wouldn't be here, but I am mechanically inclined so to speak. I hope the explanation of my issue is adequate. I have read alot of posts and it appears there are some pretty knowledgeable people commenting here at iboats. I will greatly appreciate any comments concerning my problem.
I Am Stumped,
Stephen Sands
Panama City Beach, Fl.
I Am Stumped,
Stephen Sands
