Hi guys, I have replaced my impeller on my merc 150 because I recently noticed there was no water flow out the pee hole in idle. I am not exactly sure of the year of the motor as it was put together with random parts (what I was told). So I took the old impeller and tried to match it to a new one. Same problem, no water thru pee hole at idle but flows great in gear. I thought maybe the thermostats needed to open but I let it go to 160 degrees and nothing. With the old impeller I had great flow in idle and the engine never got hotter than 120 degrees. Could I have installed the wrong size impeller? It fit just like an impeller should. Thanks. Any advise would be greatly appreciated. BTW my thermostats are gutted as it is a carb motor.
