While doing research re: the rebuild of my TN 28, I read that care should be taken that the lower unit gear lube is compatible with "yellow metal." Does anyone know if the lower unit of a Johnson TN-28 has "yellow metal?"
14 Jan '13 F_R. I received a response to an e-mail sent to Lucas Oil Products Inc. I had asked if their Heavy Duty High Performance, SAE 80W-90 Gear Oil, Trans & Diff Lube was compatible with "yellow metal." They replied it was not. I wonder if this product is intended use for a lower unit?
