Tail_Gunner
- Jan 13, 2006
- 6,237
I have been dealing with a fresh water pump leak for a while now and as usual just ran across the fact that Part 1 is considered the pump and this pump has a bearing on the outside of the shaft that cause's the failure...Is there a actual bearing that pulley it may be replaceable...a bit to cold to go out now and pull it for reference. I can find no fault in part no 6 and have replaced part 5 over and over again with the same failure.
If there is a bearing in the pump that would be the only cause i can think of that would cause the consistent seal failure.
6006-2RSC3 Ball Bearing 30x55x13 Sealed
And that would be the bearing....Edited to that could be the bearing,,,,that part number was crossed refrenced to a napa number which was the correct bearing..there is no way to know without the risk of a order.
