hbryant123
- Jun 18, 2012
- 139
On my 1974 chrysler it has not had a condensor since i have owned it. I was wondering what the condenser even does? can not having it hurt my engines performance??
"A body in motion tends to stay in motion" and this is also true for electrons. Thus under high current conditions (like energising a coil, lots of electrons flowing) the current will tend to want to keep flowing even as the switch (points) is opened, jumping the gap until it gets too wide.
Typically, on a battery ignition points engine, the condenser serves to absorb current surges when the points open and keep it from jumping the gap. This helps to prevent arcing and quick point wear.
IF your 1974 engine has the Motorola electronic ignition, the points do not carry a lot of current (amps). They are simply a 12 volt signal switch for the CD box and are not subject to much arcing. THUS: No condenser is necessary.
NOW: If you were to convert to an automotive type coil without a CD box, then you would need to install a condenser across the points.---That is, condenser body to ground and wire pigtail to insulated points terminal
