Cold whack
- Jan 12, 2013
- 14
Can any tell me what the running temp should be on this motor(1991 Mercruiser 3.0L 140 hp alpha 1). It has a 140 degree t stat which I have replaced, also replaced impeller and housing. Today I will remove elbow and inspect for any clogs. When I run it on muffs it runs about 150 when I took it on maiden voyage it got up to around 185 so I shut it off let it cool and put it on trailor. Bought ths boat from a guy who let it sit for 3 years. When I got it home it wouldnt turn over So I replaced ignition, changed oil and filter , new fuel filter, flushed old gas, rebuilt carb, new t stat, new water pump/impeller. So again I am not sure what safe running temp should be.
