Re: Adding another battery for my stereo...
Dual battery setups are very easy to install and have many advantages. You can use one at a time, use both at the same time, totally cut off power and charge both at same time. See the schematic. The isolator will prevent a component, such as your radio, which might accidentally drain one battery from draining both. You could always just power your radio from the main power supply and then when you've stopped and are just running the radio, switch the battery selector to 2 for example. 2 can be for only components while 1 is always cranking.
The other thing you could install is a Priority Start automatic battery disconnect. This device automatically cuts power when voltage drops below 11.4 volts.
Cost is about $50 for the switch, another $50 or so for the extra cables, and then the cost of a new battery. Consider one battery as your deep cycle and then the other as your cranking if you want.
