Any easy way to remove old glue from the sides of a aluminum boat. Want to paint the sides and don't think the paint will stay on over the old glue.
BTW- I've seen it asked several times what is best for removing the old carpet glue and what I found was an orange citrus spray called Goo Gone. Spray it on, let sit about 10min, and scrape with a putty knife, rinse clean. Cleans right down to alum and best of all no chemical fumes and leaves the garage smelling citrus fresh
methyl ethyl ketone (a.k.a. MEK) will do it if you dont want to grind.
Be careful with the MEK, it has hazardous fumes for breathing and is as flammable as gasoline.
Here's an MSDS for it:
http://www.sciencelab.com/msds.php?msdsId=9927358
Yep, its is nasty stuff indeed. Nitrile gloves (latex wont do) and a respirator would be a good idea with that stuff.
"Ayuh" explained: The New England Accent | Dialect | Ayuh | Wicked
