Hi everyone. I apologize if this question has already been answered somewhere on this forum, but I have searched and not found it. I have this '62 75hp v4al-14l that I'm concerned about. Got the motor with a '77 Chrysler sport fury I bought, and it barely ran when I got it. Tuned it all up, rebuilt the carb, etc, and now it runs like a champ. The last thing that bothers me is the fact that I'm not getting a voltage reading at the battery that would lead me to believe its charging. With a fully charged brand new battery, reading 12.9-13.1 volts engine off, the voltage drops to 12.6-12.7 when i start the engine and out it in gear, and idling around at low speeds i watch the voltage slowly and steadily drop over a few hours of being out. If i maintain a higher rpm, the voltage seems to hold, but it never really rises or comes close to being in the range of 13.5 or better, which I would consider charging (based on my experience in the automotive and old motorcycle world). However, I have never run it at wot or cruising range for more than 20-25 minutes at a time, since that's about as long as it takes for me to get anywhere want to go with the boat. I have made sure the diodes are good and ohm checked the stator, as per testing procedures from my seloc manual, all test good. The only thing I am not able to test, since my boat does not have an ammeter, is the voltage regulator. And unless i missed it somewhere, the seloc manual is unclear as to what the charging system voltage is supposed to be. So I guess my question is: Measured at the battery, to indicate that the system is in fact charging, what voltage readings should I be getting at idle out of gear, at idle or low speed in gear, and at wide open throttle? I know the lower unit will fail open if the voltage gets too low, and I would rather not get stranded somewhere... kinda wondering if I need to drop $200 on the new regulator or not. And I would really like to add a vhf and not worry about killing the boat in doing so. Help? I'm not an idiot, just an outboard newbie idiot. Thanks for any input.
