1969 cobia mini yacht want to paint
leb
I have a small 22' houseboat that is original on bottom and painted on topside.the bottom has some blistering and spidering I need advice on paint and proper repair tech-nicks.and I question if a houseboat that will barley do 10 miles an hour would need anti fowling paint.i would like recommendations on how and what kind of paint to use to paint the hulll of this boat
Thanks leb
jbcurt00
Re: 1969 cobia mini yacht want to paint
Needing anti-fouling paint & hull blisters are likely separate situations that need to be addressed separately. Related, yes, cause & effect, yes. But repaired as separate problems needing to be resolved.
As I understand blisters, it is caused by water penetrating the fiberglass hull's gelcoat, creating bubbles, which causes delamination (or more accurately, ARE blisters)......
1 reference
Repair & prevention of those are 2 things you need to address:
another reference
and another
Anti-fouling paint is to keep a moored boat's hull free of biological growth: reference
Hence the anti-fouling name. If there is biological growth on the hull, there is likely to be quicker & more invasive water penetration....
However, good anti-fouling (A/F) paint also adds an additional barrier coat to prevent hull penetration by water: reference
The speed at which the boat moves is of little importance to whether or not you need A/F paint......
As a houseboat that will likely be moored year round, you should fix the blisters, and use a good anti-fouling paint. Since you will be painting the hull bottom, you might consider repairing the blisters w/ epoxy. Gelcoat & fiberglass won't stick to it very well, if at all, but w/ sufficient prep, the anti-fouling paint will, and you need to paint anyway.
Note that there are few if any FOREVER A/F paints. They all require minimal regular inspection, and 1 of the above references suggests the use of a contrasting color A/F base paint, that when visible, indicates the time to thoroughly inspect or re-apply the A/F paint.
Both google & the iboat's advanced search would have quickly given you the same info.......
Welcome to the iboat's dry dock.... Where in Tn? I am currently outside Knoxville, for a family funeral.......
