dodgedakota459
- Feb 11, 2011
- 13
I need some hlep w/ 112 spl 1996 model # xe112sledr ... been running fine the last 2 years I have owned it yesterday quit running ... has fresh gas I use seafome once an while & stabal marine green stuff... motor always ran great ... took carbs abart everything looked great, did compression test 125 lbs on top cyns & 120 on bottom cyns.. new plugs... old plugs less than a year old looked ok just flooded ... fuel bulb stays hard all fuel lines look good all wires every thing seems like in good order .. not sure how to test power pack or coils or exactly where the power pach is I belive its on top of motor next tp fly wheel ... I have some wrenching skills .. just changed out cams in motor cycle & rejetted the carbs ... I will be ordering a shop manual today if some could recomend a good place to buy one from ... thanks for any & all help ... Howard
